engine knocking???
Old May 2, 2005 | 08:33 PM
seth1's Avatar
seth1
engine knocking???
Sometimes when i start my truck it makes a knocking sound but just for a few seconds. Could it be the lifters?
Old May 2, 2005 | 10:32 PM
guessrow's Avatar
guessrow
It may be the lifters...
Seth,
Give us more info on your vehicle; year, engine, mileage, etc. It may be more helpful. Is it more of a knocking sound or tapping sound??
That said, it's quite possible that it's a lifter...a bad lifter could lose its oil and tap while pressure/oil builds up in your lifter. If it's an older vehicle, I'd probably just live with the noise. If it was a newer vehicle, I'd be tempted to try to repair it...
good luck, jim
Old May 3, 2005 | 10:58 PM
seth1's Avatar
seth1
Its a 92 2.3 with a 94 engine with about 105000 miles on it. I think its more of a tapping sound. I was thinking it was the lifters. Would it be bad for the engine running it like this cuz i like to accelerate fast and shift at high rpms (usually nothin over 4k).
Old May 4, 2005 | 08:26 PM
Ken00's Avatar
Ken00
Valve noise at startup can be due to a faulty anti-drainback valve in the oil filter, also oil that is way to thick. Have you check the oil presure at startup to see if anything going on unusual.
