Electrical problem
Old May 2, 2005 | 07:34 PM
Manwith3fords's Avatar
Manwith3fords
Electrical problem
Here's the deal: I have an 88 F150, 5.0/C6 EFI. It was acting up in rainy weather so I put some new plug wires on it - problem solved. I drove it on Saturday in the rain and it worked great. I didn't touch the truck until this morning when I went to leave for work, I tried the key - NOTHING happened, no radio, no fuel pump - absolutely nothing works except for my headlights and dome light. We had over 3" of rain here Sunday and the wind was blowing it around like crazy. I checked the battery voltage, it was 12.62V, I tried replacing the ignition switch (too cheap not to try) and it didn't fix anything. I checked ther connectors at the firewall - everything looked clean. It will crank over if your short the fender mounted starter relay so the battery is fine.
I hooked my meter to the fuse box in the radio fuse position and put the key in the accessory position - the voltage is all over the place from 1-12V, totally erratic. If I try the same thing in the run position, I get less than a volt. I'm a T&T mechanic and consider myself to be pretty handy electrically but this has me stumped. I looked in my Haynes book and I can't make heads/tails of the wiring diagram as everything seems to be inter-twined in some way, does anybody have any suggestions for something that I should check?.....I need to get this thing running as it's my daily driver - I gotta take my 63 Mercury to work in the morning so I still have some wheels but I'd prefer to leave that home and away from morning traffic.
Old May 2, 2005 | 08:59 PM
Rotor's Avatar
Rotor
Try replacing the starter solonoid. (Starter Relay). If it cranks when you jump it that is a good indication that is it bad.
Old May 3, 2005 | 04:18 AM
Manwith3fords
When I have my key in the run position I have no power to my coil, accessories or anything. My fuel pump doesn't cycle either, I don't think the relay controls these too.
Old May 3, 2005 | 11:47 AM
Fords4Me's Avatar
Fords4Me
Check the fuse links @ the starter solinoid. I think it's the yellow that feeds the ing switch and the EEC relay. Without that you'd have nothing. I had to add a switch in mine for remote "kill", and brother it does it.
Old May 3, 2005 | 07:26 PM
Manwith3fords
My ol' truck runs again.....It was one of the Yellow wires under the air filter box, one of those 3 wire joints Ford is famous for with no solder or frig all.....Geeesh.......Who thought up that bright idea?.....Run's like a champ again. I called my buddy at the local Ford dealership and a technician over there told me about the yellow wire joint under the air box too, apparently it's caused quite a few F150 owners grief....LOL....Note to self: Find the electrical engineer behind this fiasco at Ford and beat him senseless....
Old May 4, 2005 | 06:16 AM
Fords4Me's Avatar
Fords4Me
Glad to hear she's goin' again.
