glow plugs again
Old May 2, 2005 | 07:28 PM
jqp00002's Avatar
jqp00002
Question glow plugs again
Okay I replaced the funky autolites gps with Motorcraft/Berus. That went along fine. I also replaced the relay (solenoid)the old one had a crack in the bakelite. I still do not get the desired results. I then disconnected the white wire and hooked up a bybass and still nothing. Should the clicking sound be heard when I hit the switch? Some of the gps insulators crumbled. There are three that have no insulation. Is this the problem. Please help!
Old May 2, 2005 | 09:31 PM
nogo73's Avatar
nogo73
You're talking about the contecters that sit on top of the glow plugs right.... if so you have to fix it so they have a good conection with the glow plugs. other wise its like you only have 5 good glow plugs so it going to act weird.
