Bronco II Ford Bronco II
truck bogs sometimes while driving
Old May 2, 2005 | 05:24 PM
Monty06's Avatar
Monty06
lately this past week my b2 will sometimes bog when i press the gas pedal
and i have to feed small amounts of gas into it and not just pedal it to the floor
i'm going to run codes this afternoon. all this happens sometimes when i'm waiting for a light to go green it won't take off. it doesn't turn off on me while driving.
and see what i come up with and post up again. but i would like your idea's on what it might be.
Old May 2, 2005 | 07:23 PM
Ken00's Avatar
Ken00
I would also look for vacuum leaks and test the fuel pressure...but you knew those answers were coming, lol.
Old May 3, 2005 | 03:59 PM
Monty06's Avatar
Monty06
code 23 koeo tps, fuel pressure ok, all vacs too.
Old May 3, 2005 | 04:50 PM
mrshorty's Avatar
mrshorty
Need to check the TPS circuit. Make sure the all wires between the TPS and the computer are intact, that the TPS has 5 Volts at Vref, and that the TPS has continuity.
