Pwr steering help!
Old May 2, 2005 | 12:01 PM
novadragman2005's Avatar
novadragman2005
Pwr steering help!
Can i go to napa or advance auto and pick up a pwr steering box to bolt onto my 69 and actually have it work right? I have a pump and bracket off of another truck already, i will get hoses later. Please let me know if this will work!!!
thnx
Old May 2, 2005 | 05:21 PM
390fe's Avatar
390fe
I don't know about Napa or Advance Auto, but you can't get a steering gearbox at O'Reilly Auto parts. I pulled mine from a truck in a salvage yard, along with all the other parts I needed.
Old May 2, 2005 | 08:18 PM
novadragman2005
well from their online store they says they have em, but thnx
Old May 25, 2005 | 09:32 AM
sgoff's Avatar
sgoff
Did you find your Power steering box ? I have 1 off a 1969, 1971 and 1975 , 2 wheel drive. If you need 1 you can e-mail me @ srgoff@comcast.net
Old May 25, 2005 | 09:39 AM
oldhalftons's Avatar
oldhalftons
thnx
yes the 67-79 power steering boxes are the same. If you are doing a power steering conversion you will need a power steering column also. the power boxes are about 4" longer than manual boxes.
pitman arms are different for manual and power boxes.
Old May 25, 2005 | 10:19 AM
ramtoo's Avatar
ramtoo
A ford power steering box won't work the steering colum is to long if you get a bendix steering box it will bolt right on!
Old May 26, 2005 | 12:05 AM
vintagerider50's Avatar
vintagerider50
Upgrading 77 highboy from ps assist to true ps_Use Bendix?
Will the bendix box bolt on to an early 77 F250 (highboy). Do you have a p/n or source?
Old May 26, 2005 | 06:25 AM
jowilker's Avatar
jowilker
NO, different animal.
John
Old May 26, 2005 | 08:19 AM
ramtoo's Avatar
ramtoo
steering box
77 is different I know the bendix will work as a direct bolt on for 67 to 72. I use to have a pic of the difference between the 2 but the bendix has a round cap on top of the gear. You can find them on ebay if you keep looking, do a search in parts for 68 ford F100 and check every day.
Old May 27, 2005 | 01:52 PM
ha2400's Avatar
ha2400
lmc truck has a power steering pump, steering gear, and hoses for my 71 its a ford not bendix and they tell me it will bolt right on.
Old May 27, 2005 | 02:35 PM
Philler's Avatar
Philler
had to install bendix when i converted from manual to power steering. The bendix you'll find in 67's only, ford after that. Mine turned out good but moved the column int o the cab by about an inch, which makes for a weird feel
Old May 29, 2005 | 10:21 AM
skuteman's Avatar
skuteman
................For a PS conversion(early77) you will NEED a heavy duty PS box from a 78-79 f250 , 4x4 . I bought mine off ebay for 150 plus freight . You will also NEED the Center Link (pn#45-2418) p.97 in the current LMC catalogue . A rebuilt PS sector box will run around 300 plus a rebuildable Core . The reason I purchased a "used box" and paid the freight goes thusly .....If you Don't have a Core and you purchase a REbuilt box they will charge you ...UP TO 200 for the Lack of a core . Now , I received my used core and DID the conversion and installed the old core with a NEW set of seals installed . IT has very little play and is working out very satisfactorily . IF , the OLD Box had proven to be TOO worn I would have purchased A REbuilt box and used my OLD core to keep from paying the "core Charge . So , it ended up that I didn't have to purchase a REbuilt core . WHY purchase a Rebuilt core when it isn't always necessary??? Others may feel differentially!!sk
Old May 29, 2005 | 10:35 AM
vintagerider50
Retro-fitting 78-79 ps sector
Thanks Skuteman. This was straight bolt up, no frame mod? I assume I can order a center link for 78-79 from any parts house?
Old May 29, 2005 | 10:43 AM
skuteman's Avatar
skuteman
............NO....this is NOT a strait boltup!! The Best way to effect the the PS conversion is to buy the COMPLETE KIT off of ebay for about 800 . NO, welding involved , just drilling of some holes and maybe a little torch work . LOTS of early 73-77 and earlier Hiboy owners have installed this KIT and are extremely satisfied with the results . sk
Old May 30, 2005 | 05:17 PM
williamwilliam's Avatar
williamwilliam
If your going from manual to power steering and just want a bolt in job, find a bendix unit. If you go with a ford unit, you will either have to find a power steering column or have your manual steering column modified by getting it cut about 2 inches for a proper fit. If you dont get it cut, the steering wheel will be all in your gut!
