Sponsored by: Kumho
95 F150 4wd steering problem
Old May 1, 2005 | 07:23 PM
Kista20's Avatar
Kista20
Sometimes after I make a turn when I correct the steering wheel to go straight the wheel wants to stick the same direction as the turn then I have to jerk the wheel to see if I can get it back straight. I just greased the front end and it's still the same. I've had it aligned when I had new tires put on and they're not wearing uneven and the old ones wore really good too.
Old May 2, 2005 | 05:16 PM
SRD4X4's Avatar
SRD4X4
Normally a "tight" or "dry" balljoint or an overtightened steering box with cause that.You said you greased everything,are the balljoints the original,non-greasable type?If they are,that could be your prob.
