Well, it's been a while since I've been here. The old girl was working all right but, I recently had to remove the "Y" pipe(92-3.0L) to do some un related work. In doing so, 3 of the 4 studs snapped off....could I heat the castings with a torch to free up the broken studs?
Your thoughts....
Your thoughts....
Did they break off flush or do you have a stub to grab with a Vise Grip? They broke off flush, didn't they? ;-)
I've gotten some studs out with an EZ-out and reverse-rotation drill bits, but I bet you will have to take the manifolds off and have the studs removed by either you or a competent machine shop. If you have the torch, it might be easy to get them out by you.
If you are planning to take them to a machine shop, it might be cheaper to get some from a salvage yard and just install the replacement manifolds instead of paying for someone else to remove them.
If you plan on doing this job yourself, have some good penetrating oil like P'Blaster or Kroil. The only good thing WD-40 does is dry out a distributor cap.
They broke off just below the nuts, and they are unique looking studs as they have a hex head in the middle of the stud that contacts the exhaust manifold flange. I'd be afraid to try to remove the manifold to cyl head bolts as they look in worse condition than the flange studs. And yes, you're right. WD-40 is crap.
I'm afraid I dont have good news for you... My manifolds were off because I replaced the engine, and even with the manofold in the vise and using a torch I had a hell of a time.
I dont want to discourage you, but I can almost guarantee that the manifold will have to come off.
I spray everything with a good penetrating solvent (not WD-40) every other day for about a week before I start the actual repair...
(I am working on a '66 Impala at the moment)
I always apply a little torque down / on before trying to take them off.
I am a firm believer in anti-seize compound when re-assembling the beast...
Lol! Thank you all for the help! Used the torch and am pleased to announce the offending pieces of hardware came out with barely any fight.
Replaced all 4 with 12mm capscrews(after chasing the threads with a tap), and a liberal coat of anti sieze compound. All good now, thanks again for the help.
Hopefully I won't be back in an I need help capacity for a while, but will be back soon to see if I can be of assistance to you as well!
Reason: typo
