Hi, I'm new to this site and need some help with making some decisions. I have a 351w with almost 200k on it. I've given it a tune-up and added a K&N airfilter kit. The engine runs good but I don't really know how much is left in this engine. I want to increase my HP but don't know if it's worth sinking alot of $$ into.
Depending on how those miles were accumulated, I would guess that your motor is probably pretty tired. Do a compression test and see what you have. Check the oil pressure with a real gauge. You will probably find that your compression and oil pressure are quite low compared to a fresh motor.
Rather than trying to increase the HP of that motor, a stock rebuild might give you more bang for your buck. You will have a nice, tight motor and then as $$ becomes available start to modify that.
Yes, the compression and oil pressure test are both good indicators.
If the compression is 150psi+ than it's good (also want all cylinder #'s to be close)...
With the oil pressure, you want to find out what psi you get when the engine is warm and idling. It should be between 40-60 psi...what most people will see on an old engine, is that the pressure is good at idle when it's cold, but when it warms up the PSI goes down, eventually to 0. I see most people going by 20 psi or higher as an indication of it being satisfactory.
Most likely, a 200k mile engine will be lower than the numbers above, but you never know until you test.
my books say 40-65psi hot@2000 rpms for the 351w
i get 20 hot idle, 45psi @2600rpms, 55psi @cold idle
last time i checked compression, i had 150psi all around
