4 Dead cylinders
Old May 1, 2005 | 11:18 AM
jcbmrizzo's Avatar
jcbmrizzo
Unhappy 4 Dead cylinders
I have a 1966 F100 That has 4 dead cylinders. They are 2,3,5, & 8. They all have compression that is good, and they have spark, and seem to have fuel. I am stumpted. Any help is appreciated.
Old May 1, 2005 | 11:34 AM
bertha66's Avatar
bertha66
If they have fuel, compression and spark, what is dead?
Old May 1, 2005 | 11:38 AM
jcbmrizzo's Avatar
jcbmrizzo
I pull the plug wire and there is no drop in rpms.
Old May 1, 2005 | 11:52 AM
bertha66's Avatar
bertha66
If you have spark at the wires but the plugs are not firing, the plugs maybe fouled out. If you have a timing light, clamp onto the plug wires to see if they are firering.
Old May 1, 2005 | 11:55 AM
jcbmrizzo's Avatar
jcbmrizzo
I have a goody that you hook up between the plug and the plug wire and it lights if the plug is firing and they all light up.
Old May 1, 2005 | 12:10 PM
bertha66's Avatar
bertha66
Have you pulled the plugs to see if they are fouled? If you have compression, fuel and spark it should be running. You may not be gitting good fuel flow from the carb. If notting is working pull the valve covers to make sure all valves are working good, no bent push rods or loose rocker arms.
Old May 1, 2005 | 12:46 PM
jcbmrizzo's Avatar
jcbmrizzo
What I have done so far is: I took all the plugs out and ran a compression check and it was good. I cleaned all the plugs and put them back in a nd used the goody to check for spark and the all lite up the plug checker. Since the dead cylinders are 2,3,5, &,8 a friend suggested the intake might be pluged since it is a split intake. I took of the Rocker arm covers and did check to see if the valves were moving and the were. Next I took off the intake manifold to finit in good shape with no blockage. Why just 2,3,5,& 8?
Old May 1, 2005 | 04:11 PM
bertha66's Avatar
bertha66
When you pulled the plugs did you put them back in the same holes? It is running, but missing? Have you looked inside the dist. cap?
Old May 1, 2005 | 04:28 PM
carras's Avatar
carras
Maybe bad plugs. Try swapping plugs between good and bad cylinders
Old May 1, 2005 | 07:13 PM
gangstakr's Avatar
gangstakr
Wink dist.
It's sounds like distributor problem make sure cap is good and not cracked
Old May 1, 2005 | 08:31 PM
BobbyFord's Avatar
BobbyFord
Half of your carb is not getting fuel. Or there is a vacuum leak affecting one half of the carb. On dual plane intake manifolds, one half of the carb fuels two cyls on each bank, one at the front and rear of one bank, the other on two inside cyls. Look at your intake runners for 2, 3, 5, and 8 and see which side of the carb is common to them and go from there.
Old May 2, 2005 | 09:18 AM
orich's Avatar
orich
I would say, Your sure doing a lot of hard dirty work first before the ez stuff too check! First 1.Stock Plugs are cheap if you go to all the trouble of remove them replace with New ones. There only good for 12,00-15,00 miles. (1)Note! never clean a plug with a wire brush it can help or make them short out! And because a plug is new don't mean it's any good!..A little light spark tester Don't mean the wire is any Good! Check your wires with an ohm meter is a Ture Test. Your Cyl. aren't Dead there not working as hard as the others.
You didn't say how much compression you have in those cyl other than good.
Good could mean it blows your finger off the plug hole when cranked over..We don't know so tell us. We have to guess that you mean it's over a 100 psi And anything less they don't work as hard as a cyl. with above 100 psi ..Hope this helps you in someway . my 2cents
orich
Old May 2, 2005 | 11:12 AM
frty7ford's Avatar
frty7ford
Just because you pull the wire off and do not see a drop in rpm does not mean you have a dead cylinder. It may mean you have 4 that are not working as hard as the others. You could have the rpm up to high the carb could be adjusted wrong. You might have low compression in those cylinders or even weak spark in them. your firing order could be off also.
Old May 2, 2005 | 11:19 AM
jcbmrizzo's Avatar
jcbmrizzo
This sight is great!!
Thanks to all of you who have written to me. I've switched plug wires from plugs that are on bad cylinders to good ones and no change. I put the plug from good cylinders into the bad ones and no change. the compression on the cylinders are 95lbs to 100lbs, no big fluxuations. The carb is spitting gas into both sides of the intake.
I had a neighbor who is great in auto mechanics and he said it has to be electrical since it is everyother cylinder in the fireing order.
I'm in the process of putting it back together and see what happens.
Thanks for all your suggestions and I'll let you know what happens next.
Old May 2, 2005 | 02:44 PM
PROSTOCK's Avatar
PROSTOCK
Do you have the right spark plug wires going to the right cylinders? Been there before...
