I have a 89 Ranger and i'am looking for a way to get rid of the goner or something semer to it??? Also i have a trans problem my over drive kicks out if you go under 45 and wont take off in o-drive you can shaft into o-d after you get up to 45 ok......
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I'm not sure what your aksing about in your first question.
For your second question, do you mean the tranny stops working completely when it's in the OD position? In general the tranny only goes into OD around 40-45 and disengages around that speed too.
