What is this?
Old Apr 30, 2005 | 07:59 PM
fast freddie's Avatar
fast freddie
What is this?
Can someone tell me what this devise is? Located just forward of the driver side battery. http://www.piczo.com/trucstuff?g=7630653
Old Apr 30, 2005 | 09:45 PM
Quadzilla's Avatar
Quadzilla
This is only a guess, but I think it's an automatic dash light dimmer.
Ok, I'll stop now.
Old May 1, 2005 | 12:01 AM
Steve_250's Avatar
Steve_250
Is it hooked up to a wire or a tube? Some type of pressure sensor?
Can you zoom out on the pic?
Old May 1, 2005 | 03:08 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
It kind of looks like one of those relays that kills a fuel pump in case of a crash
Old May 1, 2005 | 11:01 AM
fast freddie
I'll try to get a better pic. It has a little knured **** on to that can be turned so I don't think it is a fuel pump kill switch. Has an "up arrow" on it so it has to be mounted like you see it. Has wires coming out of it.
Old May 1, 2005 | 12:15 PM
fast freddie
A better pic: http://trucstuff.piczo.com/?preview=y The blue/white and the brown wires at the bottom left are conected to the divise as well as the ground you see.
Old May 1, 2005 | 12:56 PM
johnny8's Avatar
johnny8
Ok, I'll stop now.
quad man.... you kill me...!
ff .... you got me man... never seen one of those b4... let us know what you find out...!
Old May 1, 2005 | 12:59 PM
444dieselrod's Avatar
444dieselrod
The little **** on the top with the arrow can be turned????
definetly sounds like a timer of sorts. possibly for lights to stay on after they are shut off???
unhook the ground wire and see if anything weird happens.
Diesel Rod
Old May 1, 2005 | 05:33 PM
fast freddie
Mystery solved. I removed the thing so I could take a look at the back. Says Seco-larm. The wires lead to a place on the firewall where something used to be mounted. Guess it had an alarm system at one time and the little box is an adjustable motion switch.
