300 missing bad
Old Apr 30, 2005 | 07:58 PM
81fordf-100's Avatar
81fordf-100
300 missing bad
my dad just got back from a trip from alabama and i was drinvin his work van to work for a week it killed me.... and that night he got back i took her out and raced about 3 times that night the last race i was in third gear around three thousand rpms and i just felt the power drop and it started runing reel ruff i changed all the spark plugs the carb is new dunn wut the hell it could be its a dead miss wut yall think it could be?
Old Apr 30, 2005 | 11:46 PM
yendor's Avatar
yendor
do compression test and see if you have good compression,if so you my have to tear it down.Mine acted like that when I had a wrist pin bearing go on it.Also you may have bent a valve and it stuck.
Old May 1, 2005 | 09:59 AM
shortymac83's Avatar
shortymac83
what year is it? if it has the carbon filter that breathes through the carb, pull apart the carb. I had the olds suck through a couple pieces of charcoal and plug the needles. It'd shake like a dog, not idle and wouldn't go over 45 mph no matter how flat my foot was on the floor.
Old May 1, 2005 | 01:17 PM
81fordf-100
its and 1981 ford f-100 carb i just put new spark plugs in and a new carb
