Sponsored by: Auxito
Too Much ATF
Old Apr 30, 2005 | 01:43 PM
truckalpers's Avatar
truckalpers
Too Much ATF
Hey anybody know what can happen if I overfill my tranny? Just wondering cause I just added some Lucas ATF conditioner stuff but I didn't take out any fluid. Also, how do I take out fluid if it is necessary? Thanks in advance
Old Apr 30, 2005 | 04:54 PM
Ultramagdan's Avatar
Ultramagdan
If you dipstick shows ok, I wouldn't worry about it.
Old Apr 30, 2005 | 07:10 PM
wezol5484's Avatar
wezol5484
You can take one of the tranny lines off and let some drain out.
Old May 1, 2005 | 10:40 AM
Hawkeye77's Avatar
Hawkeye77
Also, if you have a drain plug in the torque converter you can drain excess there. You unthread the plug to where it just begins to leak fluid. It drains very slowly at that point, slow enough to measure with a marked container.
Hawkeye77
Old May 1, 2005 | 02:27 PM
truckalpers
That's the thing, my dipstick shows too much fluid, I'm wondering if I need to let some out. What will happen if I don't?
Old May 1, 2005 | 07:46 PM
Hawkeye77's Avatar
Hawkeye77
In a grossly over-filled transmission the fluid can become aerated and the lubrication properties deminished. That is not a good thing. How much fluid is too much? For me, anything above the full level.
Old May 1, 2005 | 08:11 PM
truckalpers
So I probably need to drain some out. Would the torque converter method be the easiest to get to?
Old May 1, 2005 | 09:00 PM
Hawkeye77's Avatar
Hawkeye77
IMO, yes. Remove the rubber drain cover from the bottom of the bell-housing. You can slowly rotate the crank with a ratchet on the harmonic balancer bolt (clockwise facing the front of the engine) and watch the torque converter turn at the same time until the drain plug appears. On a 5.8, the HB bolt head is an 18 mm and the TC bolt head on the E40D is an 11 mm. Do this with the tranny cold and the ATF drains very slowly, even with the drain plug completely removed which you don't have to do. I don't know what tranny you have so I don't know the torque spec on the TC drain bolt.
Old May 5, 2005 | 12:23 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Get Urself A Hand Pump (like The Kind Used To Pump Gear Oil) And Attach A 1/4" Hose To One End. Stick That End Down The Dipstick Tube And Pump Out What U Need. There Is Not Mess Or Leaking Plug Problems.
Old May 5, 2005 | 12:39 PM
sbeII's Avatar
sbeII
Great idea. Sounds like the easiest thing to do. Ill have to remember that one.
John
99 f-150 4x4 ext. cab(84k)
rear steel buper..grilleguard w/4 KC lights
tool box..bed linner
dual exaust..K&N air intake...
Old May 6, 2005 | 11:21 AM
2000 F-150's Avatar
2000 F-150
As BSHORT has mentioned, I just used a Mighty-Vac a few weeks ago to pull brake fluid out of my resevoir while changing brake pads and it worked like a champ.
