Stuck Distributor
Old Apr 30, 2005 | 08:14 AM
beaners1's Avatar
beaners1
Stuck Distributor
I have a '75 460 in my '86 F150 4x4, tried to adjust timing but the distributor won't move. I've had this happen before on a 351m, I ended up destroying it and replacing. Has this happened to anyone else and any tips on how to free it up.
Old Apr 30, 2005 | 11:47 AM
TxBrokenarrow's Avatar
TxBrokenarrow
mine did the same thing...penatrating oil...worked it lose...soak it for a day and if its still frozen, repeat it...i think it would be ok when reinstalling it, to coat it with a light film of anti seize... that jp blaster or pj blaster (what ever it's called) works really well...but sometimes takes a couple of applications...but you must give it time to work...usually over night
Old May 2, 2005 | 09:24 AM
1985 Quadravan's Avatar
1985 Quadravan
Yes, apply penetrating oil. Tap vacuum advance with a rubber mallet to get assembly to rotate. This will break the corrosion that is holding the Distributor in place. Poor design allows fluid to collect around the base of the distributor enabling aluminum corroision to form and freeze the thing in place. Common problem, a pain to deal with. Especially if it's buried under the A/C compressor.
Old May 18, 2005 | 10:20 PM
T18skyguy's Avatar
T18skyguy
Mine wouldnt come out no matter what I did. It wouldnt even come out when I used a 4 foot crowbar on it. So, determined to win at any cost, I got a 3 foot pipe wrench around it and-yup-you guessed it, broke the sucker right off. I was gonna overhaul the engine anyway so it didnt matter, but i just couldnt believe how it had welded itself to the block.
Old May 18, 2005 | 10:30 PM
frederic's Avatar
frederic
I'm suprised that more people don't have a large container of cleaning fluid, with either a spagetti strainer or a collander in it. I toss frozen distributors, bolts, nuts, etc into the collander, and let all that stuff soak. Then when I reinstall stuff, I wipe them off with a towel and they zip right in.
Old May 18, 2005 | 10:59 PM
Bear 45/70's Avatar
Bear 45/70
Get some PB Blaster (Wal Mart has it) and spray around the base of the dist. and let it soak for an hour or two. I use a large pair of channel locks to grip the dist. below the bell and just above where it comes out of the block. Once it is loose you can turn it easily.
