Name that part
Old Apr 29, 2005 | 07:34 PM
MustangGT221's Avatar
MustangGT221
Name that part
What is that little electrical device that is bolted to the side of the coil. It has 1 wire going in and out of it, with a plug before it. It's about 1 - 1/2" - 2" long, maybe 1/2" diameter, it's a small metal cylinder with a wire coming out each end.
I'll get a pic if I have to, but what does this do? The one on my F-250 isn't even connected.
Also, to the left of the heater unit, where the passanger side hood hinge is, is some kind of small unit with a vacuum line on it. It's in the very corner of the engine bay. Whats that? That is also disconnected on my F-250.
Old Apr 29, 2005 | 07:38 PM
XuPiTeR's Avatar
XuPiTeR
Take a pic.....
Old Apr 29, 2005 | 08:05 PM
MemOrex's Avatar
MemOrex
The passenger side thing with the vacuum is the Blend door. It should be closed when the A/C is off. (vacuum line).
I can't remember what the small cylinder by the coil is....(transistor, capacitor??)
Old Apr 29, 2005 | 08:08 PM
MustangGT221
I'll take a picture tomorrow when its daylight.
Old Apr 29, 2005 | 08:14 PM
Marc150's Avatar
Marc150
Ooooo Ooooo Oooooo!!! I Know(I think)!!! I believe that is the radio reisitor. Dont ask me what it does but I remember looking that thing up on my Ford CD And thats what it said it was.
Old Apr 29, 2005 | 08:40 PM
sphinx's Avatar
sphinx
It's a factory noise suppressor (capacitor) for the radio. Got an audible whine through your speakers when the radio is on, hook it up. Since it's not connected now, if you don't have any noise your grounds are good and you have a new christmas tree ornamet.
Old Apr 29, 2005 | 09:36 PM
MustangGT221
Yeah its disconnected now and i don't have any radio noise...
Old Apr 29, 2005 | 09:42 PM
sphinx's Avatar
sphinx
Mine went in the trash when I put the Accel coil on and I haven't had any side effects. So you got a new chrismas tree ornament
Old May 2, 2005 | 07:35 PM
MustangGT221
So that is part of the A/C system? My A/C doesn't work, I believe it needs to be recharged (fix any leaks)...but that vacuum line seems like it was cut, so that "blend door" is not working. What's it's purpose?
Old May 2, 2005 | 10:33 PM
EPNCSU2006's Avatar
EPNCSU2006
It's actually the fresh air door - the blend door is in the cab. The one you see under the hood opens anytime the vent is on (basically every setting except 'off' and 'max ac').
Old May 2, 2005 | 10:50 PM
MemOrex's Avatar
MemOrex
There we go....Fresh air door, not blend door. Sorry.
Mine had continous vacuum on it keeping it closed all the time so my A/C wasnt working right. Fixed it and everything works.
Old May 3, 2005 | 05:54 PM
MustangGT221
The problem I have, is whenever the A/C compressor is in use (A/C or defrost), you can hear the compressor click every 20-30 seconds or so, and you can feel the power loss (its very noticeable, unlike my F-150 that has working A/C). It's enough to kill the motor at idle sometimes. I figured it was just because it needs to be recharged.
What would the affect be when that "fresh air door" has the vacuum line cut off it like mine is...
Old May 3, 2005 | 06:19 PM
MemOrex's Avatar
MemOrex
The door opens when you turn on the A/C. Since yours has no vacuum, it is open all the time. That's probably not the A/C problem you have.
Old May 3, 2005 | 07:59 PM
MustangGT221
Is that what's causing air to move through the system in the cab even when it's off?
I've noticed that the heat is sorta still on even if it's in the off position and the temp is high....you move it to cool and no more heat.
Old May 3, 2005 | 08:07 PM
MemOrex's Avatar
MemOrex
Yea, that's what allows air to go into the cab. Thus, when mine was closed all the time, no air was blowing into the cab.
