Loud squeak= ball joints?
Old Apr 29, 2005 | 06:54 PM
5004man's Avatar
5004man
Sorry guys im kinda a newb, my dad has a 1993 F150 and every time he turns theres this loud squeak, is this the ball joints. I saw the post on how to replace them but I dont know if thats whats wrong. Also his 4x4 selcet is mounted on the floor, and it is harder than heck to pull into 4x4. Now is that just normal, I mean I know you gotta push it left then back.....but anyways any help would be good thanks
Old Apr 30, 2005 | 05:41 PM
XuPiTeR's Avatar
XuPiTeR
Dont push too hard, you'll break it like I did. And the dealership wants big bucks for the replacement.
Old Apr 30, 2005 | 07:02 PM
andym's Avatar
andym
Ball joints generally won't squeak. To check them, jack up each side of the truck and grab a hold of the tire at 12 o'clock and 6. Try to move the tire. If it moves even a little, you probably need ball joints. Then grab it at 9 and 3 and move it. If it moves again, you may need bearings or maybe tie rod ends.
Old May 1, 2005 | 01:00 AM
redbeast's Avatar
redbeast
You might check the CV boots as well.
Old May 1, 2005 | 03:22 PM
russt's Avatar
russt
could even be the rubbers in the sway bar - mine squeaked everytime i drove thru a dip in the road or turned corners fast enough that it loaded up the front suspension.. generally if it's wheel bearings the will growl around corners . at any rate grease the front end up anyway and see if that cures anything and have someone bounce the front of truck while your underneath ( with e-brake on and block the rear wheels) you probably will find it .
