Question on power steering hoses
It appears that the return hose on my power steering is leaking and needs to be replaced. The return line goes thru what appears to be a cooler. My question is, should I replace the return line with a standard hose or should I try to mate it to the cooler? Not knowing what pressure is on the return line I don't know if a common hose clamp would be enough to keep it from leaking where it attaches to the cooler.
Thank You
Paul
Wix transmission/PS filter
Wix transmission/PS filter #58964
Ford equivalent filter kit #XC3Z-7B155-AA
Ford filter alone #XC3P-7B155-BA
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
