TPS or more?
Old Apr 29, 2005 | 04:37 PM
wickymustang's Avatar
wickymustang
TPS or more?
This may be a little long, but bear with me on this. 95 F150 with the 300 4.9L and 5 spd. Suddenly there is a stumble at part throttle. WOT and idle nothing wrong. Can sit at a light no problem and run the freeway at 70 like no tomorrow. I checked the TPS a few months back and it was ok. IAC is clean, new air filter, plugs are fine.
If I very gradually accelerate there is basically no issue, if I go a little deeper in the throttle it will kinda lag/stumble at about 20 in second and 40 in 4th. I am thinking the TPS is going and can't keep up with the throttle plates? Any other ideas?
Old Apr 29, 2005 | 05:25 PM
Gerry Lutz Jr.'s Avatar
Gerry Lutz Jr.
Check your egr valve and for vaccum leaks if that isn't it.
Old Apr 29, 2005 | 06:10 PM
wickymustang
I tried the carb cleaner around the EGR, any other way to check for vacuum leak? Nothing happened with the cleaner.
PaysonPSD
96
May 18, 2023 10:17 PM
Olafs 7.3 ex
May 13, 2015 01:50 PM
Forddiesel17
Dec 4, 2013 04:27 PM
vroom9
Nov 2, 2008 11:42 AM
eakanator
Jun 4, 2002 07:03 AM
