1978 - 1996 Big Bronco
Overdrive light just started flashing!!!
Old Apr 29, 2005 | 11:12 AM
deepbass's Avatar
deepbass
Question Overdrive light just started flashing!!!
I have a 1995 ford bronco 5.8L and i was driving around for a little when my overdrive light started to blink. I pulled up to a set of lights. When the light turned green i began accelerating and the rpms rose to about 4 thousand rpms and then shifted very hard into second all the way to about 3rd gear. Heading onto the highway the truck wouldnt shift out of 3rd gear (RPMS were high)
when i got home later i let the truck sit for a while. When i started it up later the overdrive light was off and the transmission shifted real smooth. Then the process happens all over again. Does anyone know what causes this or what i can do to fix this? All the help is greatly appreciated!
Old Apr 29, 2005 | 11:43 AM
95 F150's Avatar
95 F150
Scan the check engine codes from the computer and figure out what's wrong. It may be something simple and unfortunately it may not.
Old Apr 29, 2005 | 11:45 AM
deepbass's Avatar
deepbass
How do i check the engine codes?
Old Apr 29, 2005 | 11:53 AM
95 F150's Avatar
95 F150
I just use my 30 dollar Actron code scanner when I need to do mine. Autozone will scan your codes for free if you have one around you.
Old Apr 29, 2005 | 12:06 PM
tHeCoS's Avatar
tHeCoS
http://dalidesign.com/hbook/eectest.html
Old Jul 21, 2005 | 09:53 AM
deepbass's Avatar
deepbass
I just got my trucks codes scanned at Aamco transmission and they found that a faulty code. I think the code was a 400 number or something. Anyhow the code that came up was for the vehicle speed sensor. Should i replace the sensor and not bother?
