mass air conversion
Old Apr 28, 2005 | 10:13 PM
bigern6697's Avatar
bigern6697
mass air conversion
Hey guys
I was just wondering where you can get a mass air conversion kit for a 89
F-150 4x4 5.0 manual transmission. And how much they cost. this is somthing i want but money is always an issue with gas prices nowadays.
Thanks
Bigern
Old Apr 28, 2005 | 10:41 PM
EPNCSU2006's Avatar
EPNCSU2006
Summit racing or Jegs carries the Ford motorsports kit for just over $600.
Old Apr 29, 2005 | 06:48 AM
frederic's Avatar
frederic
Which essentially is a $15 connector, and $5 worth of wire with some pins crimped on one end.
Find a MAF car in the junkyard, and slice the harness back carefully with a knife all the way to the EEC connector on the firewall, then remove the EEC connector, take it apart, and pop out the MAF pins, and unravel the wires to the MAF. Then take the wiring home, most yards will either give it to you or charge you something nominal like $5-$10 depending what else you're taking with you. Then buy the correct MAF from rockauto.com or similar, and you're MAF conversion is under $100.
You'll also need a computer and the injector harness, if you want to run sequantial rather than batch injection (A9P, A9L, etc)
Old Apr 29, 2005 | 09:14 AM
MustangGT221's Avatar
MustangGT221
There are many many topics on MAF conversions, please also try the search function for "MAF conv" or "mass air conversion" etc etc.
Old Apr 29, 2005 | 03:20 PM
Lumpy87's Avatar
Lumpy87
The Ford Motersport kit comes with a computer and MAF sensor as well as a filter box lid and Y adapter tube. You're paying (albiet a lot)for some added convenience. It's still a little work since you still have to remove the upper intake manifold to get to the harness. Don't you just love scraping gaskets? There may be some trick to it where you don't have to but I pulled it anyway.
If you opt to leave the old injector harness in place (which is why they call the new harness an overlay) It wouldn't be terribly hard to switch back.
I personally didn't want to try and figure out the correct wiring. It wasn't beyond my skill level to do it piece meal but I'm getting lazy these days and could afford the kit.
