Clutch Replacement or Not
Old Apr 28, 2005 | 08:23 PM
1988-Ranger's Avatar
1988-Ranger
I have a 1988 Ford ranger with a heavy duty cluth. The clutch pedal is very very stiff. The firewall area holding the master clutch cylinder has cracked and the captive nuts broken free. I have repaired the damaged area by adding new metal. The master clutch cylinder is also being replaced. Should the heavy duty clutch be replaced with a standard clutch? If I don't replace it what else could be damaged? A mechanic I know said something about a possible damage to a fork in the transmission/clutch? Thanks for your input.
