1978 - 1996 Big Bronco
Please help
Old Apr 28, 2005 | 04:57 PM
pritchard's Avatar
pritchard
Unhappy Please help
I have a 1984 fullsize bronco with a 351w, c6 trans, and a np208 t-case. The t-case is making a loud grinding noise when i try to put it into any gear. What happened was i was coming back home and when entering town i let go of the gas pedal to slow down and the truck surged a little and made a grinding noise just like when you try to put a manual trans into gear with no clutch a couple minutes later it did it again but this time it didnt stop. Pulled off the road to check what happend. Started the truck again put it in gear same grinding noise when put in gear, shut it off and tried 4wd hi same thing and then tried 4wd lo and it engaged and got home like that. Now it does that in every gear except sometimes it will engage in 4wd lo for a while. Any help would be greatly appreciated.
Old Apr 28, 2005 | 05:52 PM
MatthewC's Avatar
MatthewC
Your transfer case is toast. Start looking for used ones, or a price for a rebuild. Could be that the mechanic could install a new shift fork kit if the damage isnt too bad.
-Matt
Old Apr 28, 2005 | 09:24 PM
pritchard's Avatar
pritchard
thanx for the info. I was kinda hopeing it wasnt. I was out working on it today and the t-case fluid was very low maybe a liter and a half was all it had in it and it had metal shavings in the oil. I added another 2 liters but its still down. it engaged in 4wd lo again so i tried 2wd and it engaged again but then after awhile it started grinding again
Old Apr 28, 2005 | 10:46 PM
JetBlackBronco's Avatar
JetBlackBronco
my T-case does the same thing, but only in 4wd and at higher speeds...(40+) good thing winter is over
Old Apr 29, 2005 | 08:33 AM
kameronth's Avatar
kameronth
I am not sure about the new process, but I rebuilt my Borg-Warner 1356 no problem. I would look into a self rebuild kit for it.
