86 F350 460 replacement
Old Jul 27, 2000 | 09:35 AM
mcmary's Avatar
mcmary
Hello all, I'm hoping someone can tell me if a 460 from a 91 F350 will bolt right in to our 86 F350? Thanks! Mary
Old Jul 27, 2000 | 11:39 AM
frankenstein's Avatar
frankenstein
It will....however you have a hole bunch more issues tahn just bolt up...86 460 is carburated 89+ are FI...you could use the block and heads however you would have to get an electric fuel pump as I believe the ecentric on the cam is missing. also the cam for the FI has a slightly higher lift and short duration, so you will have to lean out your carb a little. any way if you decide this is what you would like to do tag this site for any more info there are lots of good tech/gear heads that watch this site with lots of good advise.
Old Jul 27, 2000 | 10:16 PM
bajhafords's Avatar
bajhafords
