power steering leaking
Old Apr 27, 2005 | 05:44 PM
jadel's Avatar
jadel
Question power steering leaking
i own a 94.5 F450 psd and the power stering seems to be leaking some where,iam not sure if it is the pump or the sector because there is fluid everywhere how can i tell what the problem is.Please reply thanks
Old Apr 27, 2005 | 06:12 PM
barebackjake's Avatar
barebackjake
run your hands down the lines see if you can feel a spot where its ruptured be careful on this though there could be sharp spots where it ruptured. check make sure the cap is on. remember if its leaking bad not only dont you have less power steering but less power brakes too. fire it up and see if ya can see where its spraying out of too
Old Apr 30, 2005 | 06:11 AM
norstar's Avatar
norstar
i have that too 2002 PSD f250 power steering oil leaking into the cab uk oil all over the place, no spray w/ breakes on and helper watching or when wheel is hard left or right.
Old Apr 30, 2005 | 08:52 AM
barebackjake
norstar-
you said its leaking into the cab??? check your brake booster could be leaking out the back and running down the master cylinder.
Old Apr 30, 2005 | 09:46 AM
norstar's Avatar
norstar
i pulled off the lower cover under the steering colume and followed the break linkage to a plundger coming thru the fire wall, my finger got wet w/ oil.
now the break fluid is fine the p/s fluid is always low. what part do i need to order? is it a hard job to change? i am a telcom tech by trade but lots of tools, very mechanical.
tks
Old Apr 30, 2005 | 10:10 AM
barebackjake
im an electrician dont get me started on telcom guys...j/k
should just need a brake booster. sounds like the back of its is leaking and its coming down the mastersyl boot. sure its powersteering fluid??? there not to bad to change at all. i havent done one in a superduty yet, but the one in the OBS trucks are easy. just onbolt where shaft goes through firewall and if i remeber correctly theres 4 bolts holding the mastercyl, boost assymbly on the firewall can pull that away and the master cyl unbolts off the booster and yank it out slide the new one in reconnect hose to it and reinstall. i dont have a manual for the SD yet, but thats all it intailed from a OBS truck
Old Apr 30, 2005 | 10:16 AM
norstar's Avatar
norstar
tks ,
thats why i always try to go in after ya rough in, lol
tks again
Old Apr 30, 2005 | 10:21 AM
barebackjake
make sure and pump your brake pedal before you start to bleed off pressure in the accumulator.
i do mostly utilities work, get to stay outside...learnin to splice fiber all our automation is going fiber. running fiber with energized condutors on the overhead now.
