Air Pump?
Old Aug 3, 2000 | 07:47 AM
mag's Avatar
mag
Air Pump?
I've had an intermitant chirp, that has now become a full blown squell. I think its is coming from my air pump, I had the belt off, and that pulley is the only one that has play in it. Is there a way to check for sure? and how hard and expensive is it to replace this part? Is it really needed? 92 F150 4x4 xlt with 302 v-8 auto.
Thanks for any input.
Old Aug 3, 2000 | 08:44 AM
RGAZ's Avatar
RGAZ
Air Pump?
>has play in it.
That would be a good indication that is the problem. Sometimes I have heard the pumps squeel on the belt because the intake filter (looks like a coffee can) is clogged. Check it first. Sometimes I have seen them squeel because the output hose/pipe is clogged. Check it too.
>Is there a way to
>check for sure?
What do you mean? Check for sure would be to replace the pump and see if the squeel stops. Not sure what you mean.
Not too hard, the pump isn't cheap though. I don't have the price in front of me, maybe someone here has replaced one recently.
Now here is where the rubber meets the road. Is it really needed? The air pump is ONLY for emissions purposes. At idle or high manifold vacuum situations, it directs fresh air into the exhaust to aid the catalytic converter in burning unburnt HC's. Since it is illeagal to disable emissions equipment, you must leave it alone or replace it. BUT if you did remove it and you kept the truck in tune, I bet you would pass most (not CA's or visual inspections) states emissions tests without a problem. Add a MSD 6A ignition system and i gaurantee it would pass.
Later.
Randy
88 f-150 4x4 302 5speed
Old Aug 3, 2000 | 09:05 AM
fordman148's Avatar
fordman148
Air Pump?
You may want to try replacing the belt. They tend to dry out causing a chirping sound. I just replaced the belt on my '88 F150 302 2wd and chirping is gone.
Old Aug 3, 2000 | 11:04 AM
mag's Avatar
mag
Air Pump?
>belt on my '88 F150
>gone.
This is my 2nd belt, that was my 1st concern. have used belt dressing also.
Old Aug 3, 2000 | 07:03 PM
Eddie's Avatar
Eddie
Air Pump?
