Aod
Old Apr 27, 2005 | 04:45 PM
Tyler_K's Avatar
Tyler_K
Aod
I Recently Recived An Aod That I Am Planning To Install In To My 68 Stepside, Dose Any Know , What Parts I Can Re Use Or Have To Get New, Like The Coulmn Shifter And The Flex Plate, Any Advice Or Suggestions Would Be Much Appreaciated Thx
Old Apr 27, 2005 | 06:13 PM
390fe's Avatar
390fe
You should be able to reuse your flexplate, but possibly plan on modifying your rear tranny mount, cooling lines, and shift linkage. You may possibly have to have a different starter, but I'm not real familiar with small blocks. Mabye even some driveshaft work, too.
Old Apr 27, 2005 | 10:20 PM
fordxxx's Avatar
fordxxx
If you do a search on AOD in this forum you will find a wealth of info on this installation. Note that there are many combinations of 302 and 351 flex plates that will bolt together but not work because of vibration. Also I believe there are 2 different diameters of flex plates too to add to the puzzle.
Old Apr 28, 2005 | 04:34 AM
jowilker's Avatar
jowilker
Tyler, I am pretty sure the AOD uses a Flexplate different from other automatics. You will need a special tv cable to run it as well.
Good luck on finding the parts.
John
