What Engine Control System do I have?
Old Aug 3, 2000 | 03:28 PM
TheFonz's Avatar
TheFonz
I bought a Chilton Manual for my '87 F150 four wheel drive, with a 300-L6. My engine has been running hot at times and then way cold. I was told to check the ECM. The ECM is fine. Then I was told that maybe the computer is failing. I did overhaul the engine and installed a slightly larger than stock cam. The cam is a CompCams 252 degree cam with .433 inches of lift and it said it was EFI compatible. Does this particular year have the EEC-IV system. Chilton manual isn't very clear on the '87 model 4.9 EFI. Does anyone know what engine management system '87 F150 with an EFI 4.9 have?
Thanks.
Old Aug 3, 2000 | 04:10 PM
whaynes's Avatar
whaynes
How do you if the temperature is accurate? Have you verified that the temperature sending unit is okay?
WHaynes
93 F150 4.9L 4x4
4" ProComp StII Lift
BFG 33in 4.10's
Detroit TrueTrac's
Old Aug 3, 2000 | 07:04 PM
mauzer1's Avatar
mauzer1
87 F150 has eec 4 , speed dnsity system which means you have a MAP sensor instead of a MAF sensor. Did you replace the thermostat? It could be sticking cocmmon cause to run hot one time and cool the next. Did you set the timing correctly? This will cause funny things to happen. Why don't you replace the t-stat, if not already done this is cheap and easy and then you can rule that out.Good Luck
Old Aug 4, 2000 | 05:44 PM
Eddie's Avatar
Eddie
Check your fan clutch, too. Look for goo in the vanes; mine went away awhile ago, and gave me warning syptoms something like those you're describing. It could also be a loose guage sensor connection. I doubt very much it is the ECM or cam.
Eddie
Old Aug 4, 2000 | 06:16 PM
RogerW's Avatar
RogerW
