?Assembly Lube??
Old Apr 26, 2005 | 09:01 PM
wicky's Avatar
wicky
?Assembly Lube??
I was wondering if I could sparringly use anti-seizing compound insted of assembly lube on the mateing surfaces of my rocker arms?
Old Apr 26, 2005 | 09:35 PM
Mil1ion's Avatar
Mil1ion
I wouldn't
I also don't know if there is anywhere to find out of any problems it may cause.
Old Apr 26, 2005 | 09:45 PM
DeckedoutF150's Avatar
DeckedoutF150
assymbly lube and anti-seizing are 2 differnt things as far a the chemical make up. isnt assybly lube also called chrome molly or molly lube??
Old Apr 26, 2005 | 10:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Apr 28, 2005 | 06:56 PM
Tmod700's Avatar
Tmod700
Most anti-seize compunds have either copper or nickel in them, So I would not suggest that as a assembly lube.
Assembly lube is cheap so just pick up a small tube or container of it.
Tmod
Old May 8, 2005 | 07:28 PM
F-150Guy's Avatar
F-150Guy
i would not do that, anti seize compound is very abrasive, I dont think your engine would appreciate it.
Old May 11, 2005 | 07:54 AM
Sport45's Avatar
Sport45
If you run out of assembly lube in the middle of the night mix some white grease and 30wt oil. It will work in a pinch. As mentioned before, never seize contains metal particles and will definately ruin a bearing. For cam break-in wait until you can get the proper lubricant. JMHO
Old May 16, 2005 | 09:41 PM
wicky's Avatar
wicky
thanks for the info. I too had 2nd thought about the Never Sieze and just got some assy lube.
homesteader
Nov 17, 2010 05:08 PM
mustang81
Jan 12, 2008 09:18 PM
FERacing66
13
Oct 18, 2004 08:34 PM
bryan_johnson
Oct 18, 2004 07:02 PM
Navyfe
Dec 22, 2003 07:13 AM
