DUI dizzy; max current, minimum resistance
Old Apr 26, 2005 | 11:23 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Does anyone have specs for a DUI dizzy to what the minimum resistance coil (primary) it can handle and the maximum current also? Thanks.
Carl....=o&o>....
Old Apr 26, 2005 | 02:15 PM
Franklin2's Avatar
Franklin2
DUI dizzy
What is that?
I would not recommend messing with any factory ignition system. They have it all figured out for longevity of the module and the coil.
If you want a hotter spark, go with a MSD unit or some other CD system that is designed to handle the extra load.
Old Apr 26, 2005 | 05:54 PM
buzzbait65's Avatar
buzzbait65
Carl....=o&o>....
have you tried their website....i am still tossing around the idea of getting one myself for the old 460
http://www.performancedistributors.com/
Old Apr 26, 2005 | 10:04 PM
"Beemer Nut"
Buzz, thanks for the ignition post. I want to scratch build a DUI system, as of now I have Cranes XR3000 and LX-91 coil in the FE. I would rather experiment
with parts than throw money around. I have access to a Sun distributor to get a starting point but tune to the motors needs.
Carl....=o&o>....
Old Apr 26, 2005 | 10:21 PM
"Beemer Nut"
Franklin, had 2 MSD's in the past, both failed, second one is in the center of the highway smashed up 42 miles from any human life in Nevada. Stupid me for purchasing that product twice. NOOO THANK YOU for "Miserable-Shabby &
Disfunctional". Thanks anyway.
Carl....=o&o>....
Old Apr 26, 2005 | 10:26 PM
Franklin2's Avatar
Franklin2
It looks like they are using the GM HEI setup. Am I wrong? You may find some info from someone who plays with the GM HEI. I do know the HEI has electronics inside the module that eliminates the need for a resistor to the coil +. So if you use one of these make sure you run a new wire to power the dist.
Old Apr 26, 2005 | 11:47 PM
"Beemer Nut"
Resistor wire was replaced with 14 gauge THHN years ago when I was running Allison's optical ignition system which was purchased by Crane. It's Crane's XR700 series now, XR3000 series will handle higher currents which i'm running now. Don't get me wrong the XR3000 is one great ignition system, I just want to see if I can build up a DUI and compare secondary voltage and current outputs.
Carl....=o&o>....
Old Apr 27, 2005 | 04:47 AM
buzzbait65's Avatar
buzzbait65
Carl....=o&o>....
here is another avenue, they dont curve it for you but alot cheaper and ready to run
http://www.fastengineparts.com/produ...ew.php?id=1651
Old Apr 27, 2005 | 11:11 AM
"Beemer Nut"
Buzz, you can't complain about the price but should it fail your dealing with Oz. I would rather go to any parts store for replacements. Like I posted above i'm looking for numbers like coil resistance and maximum current numbers the DUI will handle. Everyone keeps posting different ideas and avoiding the question like a politician. No offense, it sounded good to type.
Thanks.
Carl....=o&o>....
Old Apr 27, 2005 | 11:36 AM
buzzbait65's Avatar
buzzbait65
My fellow american ; I was giving you ideas of places to contact for your numbers, i figured those places would know the gm hei stuff pretty good
