Sponsored by: Real Truck
Traction bars or ladder bars?
Old Apr 29, 2005 | 02:06 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Brian,
I can probably email you some pics if you like, I have a grip of pictures, but I am semi-computer illiterate, haven't taken the time to figure out how to make an album for FTE.
Tim
Old Apr 29, 2005 | 06:59 PM
Brian460's Avatar
Brian460
Originally Posted by SoCalSuperDuty03
Brian,
Tim
Tim, that would be great I'll send my e-mail to you via PM. I am a welder by trade so fabbing some brackets will not be a problem at all. Hi HO HI HO its off to the shop I go!!
Old May 1, 2005 | 03:15 AM
SoCalSuperDuty03
Brian...
I will try and do it Sunday, been working alot, and I have one of my friends' Bobcats for a couple days....grading, setting forms, concrete on Monday.... oh what we do for more concrete to work on the toys.....
Tim
Old May 1, 2005 | 04:20 AM
SoCalSuperDuty03
Brian,
You have mail pal, I will send some more pics when I get the chance. I used 1/4 plate for the top brackets, cut elongated slots for the mounting bolts in case I want to run a bigger bag (bigger bags have wider bolt spacing). Horizontal plate of top bracket is even with the bottom of frame rail. Bottom bracket is 2x3 rectangular tubing cut into an 'a' or pyramid shape (to facilitate ease of intallation of mounting bolt into bottom of bag) 6 1/2" length on the bottom, 4" on top, 4" round plate welded to top to mount bag to. 6 1/2 length fits perfect into top springplate (u-bolt bracket) 2" width of tubing still allows removal of u-bolt nuts. Bag is Firestone 'actuator' 255c, I actually saw these first on a railroad car when I was at work, you can get them at just about any spring/suspension supply house. Trucks I have done with less lift use slightly different variation of the top bracket, and I usually mount it up higher on the frame rail. Compressor and tank are on the right side frame rail, tank just clears the AMP Research PowerStep when it folds up against the rocker panel. I use a twin paddle switch and two needle guage, so I can put air in the bags independently.
let me know if you need anything else
Tim
Old May 2, 2005 | 07:33 PM
Brian460's Avatar
Brian460
What kind of compressor are you using? Is it cheaper to piece it together or buy a kit?
ReBilld
24
Mar 25, 2013 06:32 PM
Graeme
May 9, 2011 12:13 AM
rootbeerford
Jun 24, 2009 02:06 PM
Franken-Truck
Offroad & 4x4
23
Oct 10, 2005 10:07 PM
