Sponsored by: Auxito
engine feed back on 4.6 litre
Old Apr 25, 2005 | 09:28 PM
Headstone's Avatar
Headstone
Well my 94 f150 has a little over 350,000 km's on it and I'm looking at 2001-2004 F-150
anybody have feedback on the 4.6 litre engine? good... bad... other problems?
Old Apr 25, 2005 | 10:54 PM
Tallmote's Avatar
Tallmote
My 98 F-150 SBSC 4X4 4.6 has 155,000 mi on it and it runs like new. Uses no oil. Very satisfied with it.
Old Apr 26, 2005 | 06:37 AM
bigdaddyII's Avatar
bigdaddyII
177000 miles on a 97 4.6. no engine problems whatsover
Old Apr 26, 2005 | 07:56 AM
christaylor's Avatar
christaylor
If you are looking to tow or haul alot I would go with the 5.4 I have a 4.6 and love it but I do not do alot of towing or hauling with my truck. Don't get me wrong the 4.6 is great but...
Old Apr 26, 2005 | 09:52 AM
ddrumman2004's Avatar
ddrumman2004
146,000 on my 97 4.6...and it runs great.
Old Apr 26, 2005 | 09:53 AM
Smaug's Avatar
Smaug
103k on my 97 w/ no problems
Old Apr 26, 2005 | 10:21 AM
MrBSS's Avatar
MrBSS
97,000 miles on my 2001 4.6. It's just like new.
I did have some concerns about top end wear with an overhead cam engine that is started and stopped frequently, so I put a pre-oiler on it. This is a race item that works like a well pressure tank, and supplies up to a quart of pressurized oil if the pressue should fall or before cranking the engine.
Possibly overkill, as I haven't seen others having cam or valve train wear as a problem.
Overhead cam engines are generally considered better and more modern, although they have fallen out of favor because they cost more to build, and are slightly less compact (push rod engines tuck the cam down within the block). These are problems for the manufacturer, not us.
The Triton V8's are recognized among the best engines built anywhere in the world.
PS: I should mention that two of the COPs (Coil on plug) have failed on my truck. It's a lousy place to put a coil, but the engineers had good reason for doing this. I think the new parts are tougher, and at least when they fail you're never stranded; usually the SES light goes on when the problem is barely noticeable. That, and a DPFE sensor, have been my only problems.
