Stock distributor questions
Thanks,
JC
At the bottom is a plate that has those slots in it and they limit the mechanical advance according to the number that is stamped on the plate.
To change it just rotate the post 180 degrees and you hve now changed from 10L to 16L or vice versa.
When you change the post you also in essence made the distributor 180 degrees out.
Tmod
I always just pull the distributor up and rotate it.
I also modified my slots by welding them shut more to limit the mechanical advance even more then is available with the factory slots. You can also find different reluctor posts that have different timing slots in them.
Tmod
Does the reman one have a bushing at the bottom of the housing? Most electronic version's come without a bushing at the bottom and I end up machining the housing and a oilite bushing to put in there.
Tmod
What you need to do is look in the middle of the shaft and you will see a felt wick, Just remove that and you will see a little snap ring with the tabs facing upward.
Take two picks and go in between those tabs and push them apart and try and lift the snap ring out of there.
After that just lift the cam out and do whatever you need to do and re-install.
How much metal are you looking at adding? And why?
Tmod
Here is my setup on my 390. I can run regular 87 octane without any pinging.
Distributor Timing Specs:
Initial Timing Advance 16 BTDC @ 800 RPM
Full Centrifigual 8 BTDC @ 2500 RPM
Initial & Centrifigual @ 2000 18 BTDC
Vacuum Advance @ 5" 0
Vacuum Advance @ 10" 3
Vacuum Advance @ 15" 14.5
Vacuum Advance @ 17" 18
Centrifigual Starts @ 1800 RPM
Total Initial & Centrifigual 24 BTDC @ 2500
Total Timing @ Idle 800 RPM 34.5 BTDC @ 800 RPM
Also here is the dimensions of what you need to close the slot width down to for a particular timing limit.
10 degrees centrifugal advance = .280"
12 degrees centrifugal advance = .306"
14 degrees centrifugal advance = .332"
8L slot = 16 degrees centrifugal advance = .358"
9L slot = 18 degrees centrifugal advance = .384"
10L slot = 20 degrees centrifugal advance = .410" Total slot width
11L slot = 22 degrees centrifugal advance = .436
12L slot = 24 degrees centrifugal advance = .462"
13L slot = 26 degrees centrifugal advance = .488"
14L slot = 28 degrees centrifugal advance = .514"
Oh and yes change the springs as the weights will slam and bounce with the stock springs.
Tmod
Just buy the Crane Vacuum Advance kit and it will contain a new vacuum canister and some springs.
Tmod
Which one is there two of? Been awhile since I did mine.
I want to say use one yellow and one silver.
I think there are two silvers in the kit.
After installing the springs bend each outer ear out about 1/32" of a inch.
That setting should get you pretty darn close to the same timing curve that I have.
Now if you have a hand vacuum pump just have the engine running at idle and adjust the vacuum canister until your vacuum timing matches my settings.
You will now have a good baseline if not a great timing curve that matches the 87 octane as well as performance and fuel mileage.
Tmod
