Texas Chapter Join Chapter, Leader: LibTimothy
Distributot/Pick Up Coil
Old Apr 25, 2005 | 09:19 AM
Cicobra's Avatar
Cicobra
Smile Distributot/Pick Up Coil
I mentioned on this forum about a week ago regarding how my '84 F-150 would just stop running while driving, then begin running again all on its own without warning. Never knew when this would happen. I felt that the problem was definetly electrical, and after checking every possibility, I discovered that it was the Stator in the distributor. (Sometimes referred to as the Pickup Coil - [Type Ignition: DuraSpark II; fender well-mounted ignition module. You may need to know this info if you have to replace the Pickup Coil.]) If you're not aware of the culprit that's causing what I call "Dead-Stop" stalls", or if the engine will not start at all after everything else has been checked, you may want to consider this little "bad boy". If you're a novice at this, you'll want to keep this in mind. Just thought I'd pass this on.
Old Apr 26, 2005 | 04:23 AM
rlmdad's Avatar
rlmdad
Isn't this pickup also known as the hall-effect sensor?
Used to lease an new EXP that started doing the same thing before I started doing my own work...Almost killed me once as I had a semi hauling down on me when it decided to quit...Had to veer off the interstate to avoid being pushed off...Let it cool off, started right up and ran for a while then after it heated up would quit again... Limped in to the dealer who replaced the sensor, never happened again.
Ron
RL7
1997 - 2003 F150
25
Jan 6, 2025 02:15 AM
mxhowes1
Nov 11, 2011 08:39 PM
Olbeater
Nov 1, 2010 05:31 PM
Newfoundpurpose
Jan 27, 2009 08:19 PM
UGLYOLDFORD
Mar 6, 2006 12:44 PM
