Engine swap wiring
Old Apr 25, 2005 | 08:04 AM
Kazco's Avatar
Kazco
Engine swap wiring
Can someone give advise or point me to the right area.
I have a 1967 F100 with the 240 six engine. I plan on swapping it out and put a 302 in.
My question is....what wiring changes would need to be done. I would like to put HEI distributor in also.
Any guidance on what wire goes where would be great. Do they make a replacement engine wiring harness?
Thanks in advance,
Mike
Old Apr 25, 2005 | 09:09 AM
Mike G's Avatar
Mike G
Depends on what 302 you want to put n... If you are going with just an old fashion carbed 302, then all your wiring will work. Yo will probably need to bypass the resister wire from the ignition switch so you can get 12v to your coil and then you can run any ignition system you desire. Check out the "Performance-General Engine" forum, there is a thread in there near the top already about DUI and various ignitions. I just put a DuraSpark distributor and HEI module into my 65, only had to bybass the resistor wire and up the gap on the plugs. https://www.ford-trucks.com/forums/s...d.php?t=327065
--Mike
Old Apr 25, 2005 | 09:16 AM
Kazco's Avatar
Kazco
Thanks Mike G,
That's exactly the info I was looking for. Yes, I'm just putting in a basic 302 with a carb.
Thanks again,
Mike
Old Apr 25, 2005 | 09:22 AM
Kazco's Avatar
Kazco
One more question, do you happen to know exactly where the resistor wire happens to be?
Thanks,
Mike
Old Apr 25, 2005 | 01:24 PM
ronclark's Avatar
ronclark
If you are going with the duraspark II ignition, I think you need the resister wire to keep from burning up the module. I uses 12 volts to start but runs on about 9 volts.
Old Apr 25, 2005 | 01:39 PM
Kazco's Avatar
Kazco
What if I do not use the duraspark Dist. I really do not need that high performance dist. Just your basic.
Thanks,
Mike
Old Apr 25, 2005 | 02:38 PM
ronclark's Avatar
ronclark
The Duraspark ignition isn't a high performance ignition. It is the standard electronic ignition used of all ford v8 cars and trucks since 1976 or 77. First ones was the Duraspark I followed by the Duraspark II. Both required the resister wire. If you are going with the Chevy HEI, then the resister wire isn't needed.
mj_355
Jan 7, 2014 07:44 PM
1990-f250
Jul 9, 2013 08:26 PM
FarmerFrank
1978 - 1996 Big Bronco
Apr 5, 2010 03:30 AM
tabascom16
Mar 10, 2008 05:54 PM
Luke Peterson
Nov 8, 2004 05:33 AM
