Sponsored by: Real Truck
Anyone Use Precision Gears?
Old Apr 25, 2005 | 04:13 AM
hc130flyboy's Avatar
hc130flyboy
I am looking at buying gears for my SD from Precision Gear. I want to go with 4.56's but it looks like all they have is <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR class=sitetext><TD bgColor=#dfdfdf height=18>
4.55
</TD><TD bgColor=#dfdfdf>
41-9
</TD><TD vAlign=center bgColor=#dfdfdf>
F10/455L
</TD></TR></TBODY></TABLE>
For the Rear gears, and
<TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR class=sitetext bgColor=#ffffff><TD height=18>
4.56
</TD><TD>
41-9
</TD><TD>
50D/456
For the Front. The 1st number is the Ratio, 2nd is # of teeth and 3rd is Part #.
My question is, this looks pretty simple they both have the same number of teeth. but why is the ratio different? Is having the different ratio ok?
Another question is I have the 10.50 Rear and the Rear gears here are 10.25 do I just get 10.25 bearings and be done, will my diff work?
Old Apr 25, 2005 | 11:37 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Flyboy,
The gears are actually the same ratio, for all intents and purposes. Some manufacturers actually have different ratios (slightly, i.e. 4.10/4.11) for different differentials. They work perfectly together. You didn't say what year your truck was, and Gas/Diesel, and what current ratio (3.73/4.10/4.30, etc.) Do some more research on gearsets. Precision is definitely not the first choice I would make, and I have used them in the past.
Tim
Old Apr 25, 2005 | 01:42 PM
hc130flyboy
SoCal,
The truck is a 2000 F-250 CC with a 5.4 and 3.73 gears. 37" tall tires
Old Apr 25, 2005 | 02:06 PM
SoCalSuperDuty03
flyboy, check your personal messages.
