1978 - 1996 Big Bronco
change the tranny
Old Apr 25, 2005 | 12:32 AM
88buildabronc's Avatar
88buildabronc
change the tranny
hey guys, anyone (i'm sure greystreak does) know how much it should cost to take my 88 with a C6 tranny and switch it over to the E4OD? Yes i know that the C6 is bulletproof but having three gears and a good amount of 55mph+ driving with the price of gas....poor mix. Also......KNN filters.....what can you say about them other than......thank you?
Old Apr 25, 2005 | 03:52 AM
aurgathor's Avatar
aurgathor
Switching the tranny itself might not be that difficult, but you also need a control module, which I believe is part of the engine computer, and that could be a tad difficult to overcome.
If you do lots of hwy driving, you can try to increase the tire diameter an inch or two, or put in a bit taller (numerically lower) gear. That *may* help a little.
Old Apr 25, 2005 | 11:11 AM
Kemicalburns's Avatar
Kemicalburns
you can swap in an AOD easier or go to a 5speed manual. the e4od is pretty much out of the picture but can be done with $$$
Old Apr 25, 2005 | 07:56 PM
kameronth's Avatar
kameronth
Like kemical said, I would look into the AOD if you want to stay automatic. The e4od would require a computer change. The AOD can be very strong also if you build it up right.
