Sponsored by: Real Truck
shift knob and engine upgrades
Old Apr 24, 2005 | 06:11 PM
strokinnova's Avatar
strokinnova
shift **** and engine upgrades
I have 2 questions. The first one is there anywhere that makes like a billet shift **** and does the **** screw on or does it just pop off. Also will engine perfomance upgrades be the same for a 5.4L 04 F-150 and an 04 SD F-350 with the 5.4L....Example air intake, chip, UD pullies (if they make them)
Old Apr 25, 2005 | 03:18 AM
hc130flyboy's Avatar
hc130flyboy
Intake kits are different between the 150's and superduties. The F-150 intake is straight out the front then routes to the drivers side, where the SD TB is routed at a 45 degree angle then the piping routes to the drivers side. the pulleys
I believe are the same, mine worked, Chips or programmers will work but your better off getting vehicle specific for shiftpoints etc. Not too sure about the billet peices you mention
Old Apr 25, 2005 | 08:07 AM
strokinnova
where is there a site with SD upgrades all i can find are for the f-150
