picklex-20 amount needed?
Old Apr 24, 2005 | 05:38 PM
4x4bronco92's Avatar
4x4bronco92
I need to coat the interior of my 79 Bronco with Picklex-20. Should 1 quart be enough or do I need to get the gallon?
Old Apr 25, 2005 | 07:16 PM
Greg 79 f150's Avatar
Greg 79 f150
A quart will be good , just cant waste it tho. Use it only on the bare metal or rust, not painted surfaces. I put mine in a one quart hand pump spray bottle and applied it. Be careful of spraying in close quarters tho, it will burn skin and irritate eyes/nose. I didnt like using a brush, because when brushing upside down , the p20 would run down my hand, plus having to keep sticking the dirty, rusty brush back in my p20 bugged me. So, I just sprayed it on to wet ( not enough to run off the metal tho ) the rusty spots. Then I let it set for two minutes, then wiped the treated metal off with a clean cloth. Be sure to let dry well before applying topcoats. good luck, jmo
Old Apr 25, 2005 | 07:46 PM
4x4bronco92
The whole interior will be wire brushed and sanded to bare metal then wiped clean...so I will probably use the brushing method. Plus, I'm only doing the floor of the interior. Thanks for you input...I ordered the quart.
aldridgec
Aug 22, 2021 02:16 PM
Gen 1 driver
1978 - 1996 Big Bronco
Oct 24, 2015 08:52 AM
Christopher2
Paint & Bodywork
May 7, 2005 10:23 PM
sancochojoe
Mar 22, 2005 05:07 PM
sancochojoe
Paint & Bodywork
Mar 21, 2005 02:57 PM
