10.25" tough enough?
Old Sep 1, 2000 | 10:29 PM
dan18156's Avatar
dan18156
I am building a bulletproof 4x4(hopefully) and have some questions on rear axles. I have recently visited Dynatrac.com and read that besides the Dana 70 and GM 14 bolt the Dana 60 has the largest pinion and carrier support bearings compared to other axles. I found that hard to belive considering that the Dana 60 was almost exclusivly used in 3/4 ton trucks and the Ford 10.25" was used on f-350 duallies untill 1999. Is the 10.25" axle prone to breakage in the bearing? I pull in the local truck pulls and am wondering wether I should get rid of my 10.25" axle in the back of my 1996 f-250HD in favor of the much more expensive Dana 70, or keep the oem? When at the pulls i noticed that many of the purpose built pullers used the GM 14 bolt; even the fords! My next question should be a little easier but none the less important. Is it possible to use wheels from a single rear wheel truck and put them on a Dana 80 that origionally came with duallies? And if i do that will i keep the same width of track in the back as in the front? Any information is greatly greatly appreciated!!
Old Sep 3, 2000 | 11:25 PM
PAUL_2's Avatar
PAUL_2
79Supercab
Jan 7, 2015 03:56 PM
BruteFord
Apr 1, 2013 04:45 AM
nowafordman
Jul 23, 2011 12:21 AM
mustanginca
Feb 9, 2008 06:33 AM
BlackSheep
Offroad & 4x4
Apr 24, 2000 08:08 PM
