Adding Sirius Radio
Old Apr 24, 2005 | 12:21 AM
ppodojil's Avatar
ppodojil
Adding Sirius Radio
Hello to all the loyal X owners! This is my first time posting at this site. I am impressed by all the great info and feedback on this site.
I have an '01 Limited with the in-dash 6 CD changer. I want to add a Sirus tuner but do not want to use an FM modulated setup because of the poor sound quality. Do any of you know of an auxillary input adaptor that will work with the factory head unit? I have seen an adaptor that will work with the older headunits that use a remote CD changer (changers often mounted in the center console) but those will not work with the head unit in my truck. Any ideas?
Old Apr 24, 2005 | 08:58 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 24, 2005 | 04:11 PM
2l8iwon's Avatar
2l8iwon
Does your truck have the factory DVD system if so do what I am doing with my X which is use the factory aux input. If not I am not aware of any adaptor, I know the explorer head unit is factory compliant with Sirius but I have XM in both my trucks, and both are using the DVD Aux input.
Old Apr 24, 2005 | 04:38 PM
yellowducman's Avatar
yellowducman
I've also looked for an adapter for the same reason with no luck. I think having the 6 disk changer in the dash is the problem. No provisions to hook up somthing externaly. I am using the fm modulator in mine for the time being but I would like to upgrade the headunit to an aftermarket that supports GPS. That comes to the next problem of not being able to find a adapter to use the factory dvd system with an aftermarket radio. The aux imputs that 2l8iwon refers to seems to be a good way to go, not for me though because I use a sirius reciever mounted in the truck and I need an FM modular or a head unit to control it. My two cents anyway.
Old Apr 25, 2005 | 07:21 AM
ppodojil's Avatar
ppodojil
I do not have the DVD system in my truck. I think I will wind up replacing the head unit with a Kenwood unit out of my last truck. This head unit is not set up for Sirius but there is an adaptor that will covert the CD changer input on the Kenwood head unit to a pair of RCA's to be used as an aux. input. I will still have to use the Sirius tuner to change stations but at least the sound quality will improve. Thanks for the responses.
Old Apr 25, 2005 | 02:18 PM
Hello's Avatar
Hello
Thanks!
I do have a factory DVD player and will try it. My FM modulator has a lot of static, and if I get in an area with strong competing station, it get all garbled.
Old Apr 25, 2005 | 03:22 PM
Hello's Avatar
Hello
Just connect it to the AUX inputs on the DVD player, and switched the radio to DVD AUX. Works like a charm! No more static!
Thanks again!
Old May 9, 2005 | 10:21 AM
rossgn's Avatar
rossgn
Sirius Static
Thanks again!
DO YOU JUST PLUG IT IN ON THE FRONT? I DON'T WANT TO SEE ANY WIRES.
Old May 9, 2005 | 02:48 PM
Hello's Avatar
Hello
I pluged mine in the DVD Video inputs on the front, and let the cable dangle down below the passenger seat armrest. Then to my Sirius. Yes it is visible but doesn't interfere with anything. It's too much trouble for me to fish it thru the headliner, the molding, then under the carpeting, but you can do that. If you are knowledgeable, you can find a way to hook it directly to your radio.
BTW if anyone is watching DVDs in the back seat using headphones, you can't play your Sirius using the jacks. It will only play the DVD movie sound. But the CD player and radio will still work.
svfetter
Jul 25, 2013 05:30 PM
cdnalpina
Sep 8, 2010 04:31 PM
hank89
Oct 25, 2007 11:21 AM
rel3rd
Dec 3, 2006 09:32 AM
Jackflack
Apr 14, 2004 05:01 AM
