Aerostar Ford Aerostar
Aerostar Headlight Switch
Old Apr 24, 2005 | 12:19 AM
duhlry's Avatar
duhlry
Ok, well, I posted a while ago that I was having problems with my headlights. All of my other lights work and the headlights work when I pull the flash to pas but not push forward for constant high beams. Well, after replacing the bulbs and the headlight switch I decided to take the steering column apart and I took out the turn signal/wiper/high beam switch and as I was looking inside it I realized that everything was blackened and that there was water damage. So I am thinking that this is going to be my problem but I was just wondering how common this problem is? Is it a known problem that would have been taken care of by a Service Bulletin????
Old Apr 24, 2005 | 12:59 AM
Bear River's Avatar
Bear River
Former ******
It would not have been taken care of by a service bulletin. It is a fairly common problem however. A new part at Autozone or some other parts store is cheap enough, and at least as good , or better than, the original.
