Information On 351 Buildup
Old Apr 23, 2005 | 06:57 PM
robsroofing's Avatar
robsroofing
I Am Rebuilding My 1985 351w And Would Like To Do A Non Emission Mild Performance Engine. I Have Done A Couple Of Engines But Always Put Everything Back Stock. I Would Like To Get Information On Exactly What It Would Take To Set This Up Properly. I Am Not Sure About Vacuum Lines Etc.. Any Info Or Resources Will Be Greatly Appreciated
Thanks
Rob
Old Apr 23, 2005 | 07:04 PM
robsroofing
I Accidentally Posted This In The Wrong Place
Old Apr 25, 2005 | 12:41 AM
mako5972's Avatar
mako5972
It all depends on the amount of money you want to spend. List a budget and some people can help.
Old Apr 25, 2005 | 02:25 PM
ronclark's Avatar
ronclark
I can give you some ball park figures Assuming that your crank and rods are OK. Pick what you want.
Machine work on lower end: Hot tank, magnaflux, decking, checking if needed align boring, cam bearings, press on pistons, and polishing or turning crank. $400-$500
Rings and Pistons : Kit from Summit including hypertheratic pistons, rings, rod bearings, main bearings, cam bearings, oil pump, gaskets and freeze plugs: $315
Cam and Lifters: $150 Call Crane or CompCams after you decide on what heads before buying.
Edelbrock manifold 4 barrel: Use Performer or Performer Air Gap $170 - $225
Carb : Holley 4160 600 CFM $275
Roller Rockers : Crane pedistal mount $200
Headers: Hedman Elete series $275
Fuel Pump Water Pump: $100
ARP Rod bolts and Head bolts: $85
Heads: Here is where you determine how mild or wild you go.
  • Stock heads without porting or you port - Machine shop work $300++ to deck, 3 angle valve job, replace necessary guides, New springs.
  • Stock heads professionally ported. $500+
  • GT40p heads $750
  • Aftermarket heads $900 - $2000
My motor cost me about $1800, but I did my own head porting and already had some of the parts.
powerstroker02
May 11, 2010 09:04 PM
j30rdesign
Engine Swaps
Apr 18, 2009 01:49 AM
75 SuperCab
31
May 18, 2007 10:03 AM
crzyone
May 5, 2007 06:31 PM
robsroofing
Apr 26, 2005 07:23 PM
