dual exhaust
Old Sep 7, 2000 | 06:51 PM
matt68's Avatar
matt68
dual exhaust
can u get dual exhuast on a 300 i6? I have heard you can get a muffler with one inlet and 2 outlets or that i could get a splitter pipe and run glasspacks off of each tube. Can u do the second idea which is the loudest? i want it to be really loud! Thanks matt
Old Sep 7, 2000 | 08:07 PM
Pastmaster's Avatar
Pastmaster
dual exhaust
Matt, you can do anything you want. But it should be legal. I would recommend going with a straight-pipe. It's cheap and will usually last longer than a muffler would. A cat-back system is about the only legal setup anymore, and it usually load. Weither you go with a dual setup or a single 3", I doubt there would be much of a noise difference.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
Old Sep 10, 2000 | 07:24 PM
82F100SWB's Avatar
82F100SWB
dual exhaust
You could get a header for it, or the dual exit manifolds off of a 87-96 Truck, both will give you true duals, if you have a truck that is emissions exempt and you want it loud, mount a set of short glasspacks as close to the engine as possible, and make the tailpipes as short as possible, and it'll be as loud as possible while still being legal, same thing applies to a single exhaust, only ya won't have the neat I-6 with true duals sound.
Evan MacDonald
82 F100 FlareSide
HD 300-6
NP435(6.69 low)
2.73 Geared 9"
Old Sep 10, 2000 | 07:36 PM
hotrodford_88's Avatar
hotrodford_88
dual exhaust
[font size="1" color="#FF0000"]LAST EDITED ON 10-Sep-00 AT 08:39 PM (EST)[/font][p]I had a glass pack on mine when it had the 300 I-6 in it. It didn't have any kind of sound, until I put a stock muffler & tailpipe on it.
Mine even had a turn down right out of the glass-pack, and there was still no good sound from it. It was just as quiet as a stock exhaust system. Now, when I changed the Catalytic convertor on it that made a difference. Even with the stock muffler & tailpipe it had some sound.
JC Whitney sells an exhaust kit that splits behind the Catalytic convertor with two pipes and goes straight to the back of the truck with split pipes (Dual Exits). The tips have packing in them, which makes them the mufflers. They say the kit is emissions legal and sells for about $229.95
Try their website.
http://www.jcwhitney.com
And here's the link straight to the systems for 80-96 ford pickups.
http://www.jcwhitney.com/productnoitem.jhtml?CATID=33985
Old Sep 11, 2000 | 10:54 AM
maveric's Avatar
maveric
dual exhaust
Just my $.02 worth. I have a true set of duals with 24" trashcan glasspacks. I have had them on for about a year now, and they are the most obnoxious, annoying things I have heard. I am not running a cat, so they are the only thing on the pipes. I have the tips on as well. LOUD...
Also, unless you want to do a bunch of custom work to the prebent system, go somewhere and have them do it professionally. I bought a system for $199 from JCWhitney, and spent 8 hours under my truck getting it to fit. The bends were all in the wrong spots, nothing fit together correctly, etc. I could have went to an exhaust shop, had them bend it out of 2.5" pipe, with mufflers, and tips for about $250. I wanted to do it myself, so I did. They say hindsight is 20/20, should have spent the extra $50 and saved the time.
Old Sep 11, 2000 | 01:43 PM
jaberwock45's Avatar
jaberwock45
dual exhaust
