What rear do I have?
Old Apr 23, 2005 | 06:24 AM
Cricket460's Avatar
Cricket460
I own a 94 Explorer 2 door 4.0 4x4. I am running 35" tires on it. I need to put a taller gear in the differentials. Do these trucks use the 8.8? If so what spline are they? What "rear" do they use in the front? How can I tell what ratio I have now? ThanQ - Randy
Old Apr 23, 2005 | 08:12 AM
Monty06's Avatar
Monty06
explorers have a d35 up front with a 8.8 rear with ratios starting i think around 3.45
spline 31 i think not so sure.
Old Apr 23, 2005 | 08:49 AM
mrshorty's Avatar
mrshorty
He's correct, the rear is a Ford 8.8 axle with 31 spline axleshafts.
Front is a Dana 35 TTB.
Easiest way, IMO, to tell gear ratio is to check on the metal tag bolted to the rear differential (if still intact). 2nd line will start with a series of numbers representing the gear ratio (3 73 for example).
Old Apr 23, 2005 | 09:49 AM
Cricket460's Avatar
Cricket460
The 8.8 will be easy enough to find replacement gears for, but who carries a ring & pinion for the front Dana 35? -Randy
Old Apr 25, 2005 | 03:21 PM
Jharger's Avatar
Jharger
Dana 35's are actually more common than Ford 8.8 diffs - when you consider all the Wranglers out there. All the major manufactures make ring/pinion gears for it. Check 4 -wheel parts.
Old Apr 26, 2005 | 08:57 AM
Torsen Rick's Avatar
Torsen Rick
Aren't the D35 axles in the TTB trucks a reverse cut though? That makes the gears different from the ones used in the rear of a Jeep...
Old Apr 26, 2005 | 11:01 AM
Jharger's Avatar
Jharger
Not sure. Please let us know when you finish your research.
