Modular V10 (6.8l)
Unknown mis-fire
Old Apr 22, 2005 | 05:44 PM
Firemedic61's Avatar
Firemedic61
Question Unknown mis-fire
Had my truck at the shop today for a mis-fire that begins at 1500 rpm through 3500. They preformed all test including drivability, but found nothing. Now what? I think that it is a coil? Does anyone have any ideas on how to verify the problem?
Old Apr 22, 2005 | 08:01 PM
pumpdriver20's Avatar
pumpdriver20
Hello Firemedic61,
I had a rough idle problem in my '04 V10. Took it to the dealer and they ran all the "test" they could and all showed normal. The tech took it out for a drive and confirmed my problem. He said he did some more "testing" and and the computer was showing an occasional mis-fire on the #6 cylinder but was suppoesedly within normal ranges. He tested the #6 coil and it was fine too. Finally he replaced the sparkplug and the problem was solved. Never had a problem since.
I guess what I'm trying to say is that all of their test can show normal and there still is a problem. Lucky for me my tech was motivated enough to keep digging and eventually solved my problem. Even though the all his diagnostics said everything was working within normal limits.
Stay on the service dept. until you get satisfaction.
Sounds like we are in the same line of work.
Good luck,
Pumpdriver20
Old Apr 24, 2005 | 07:12 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Firemedic61...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 25, 2005 | 08:57 AM
V10dave's Avatar
V10dave
I just went through the same thing... It was the plugs. Change 'em out.
Old Apr 25, 2005 | 01:08 PM
Big Orn's Avatar
Big Orn
If the drivability test couldn't find the problem, you may have to load the truck and then test it. The problem could surface more readily when laboring.
