99 Ford Explorer AC Problem
Old Apr 22, 2005 | 05:07 PM
wiznewski's Avatar
wiznewski
Need to add freon. Compressor kicks on above 2000 RPM.
when I check on low pressure side with car at idle pressure reads 175, compressor not running. I am afraid to add freon. What should I do?
Should I increase engine speed until compressor runs then add freon.?
Old Apr 26, 2005 | 05:52 PM
Ultramagdan's Avatar
Ultramagdan
Your low side pressure is way high from the sounds of it. Are you sure you haven't overfilled it?
Old May 1, 2005 | 05:43 PM
wiznewski's Avatar
wiznewski
The Ac worked fine last year. When I checked it in 2004 the pressure was okay.
Can it be an electrical problem?
Thanks
tolmite
17
Jun 28, 2018 02:04 AM
proyer
6.4L Power Stroke Diesel
Jun 10, 2015 01:50 PM
57texasranger
Jun 24, 2013 06:58 PM
jllaco
18
May 30, 2013 11:57 AM
jllaco
May 24, 2013 11:27 PM
