Coolent Flow
Old Apr 22, 2005 | 01:57 PM
gwuister's Avatar
gwuister
Coolent Flow
What direction does the coolent flow on a 5.0? From the rad through the thermostat into the engine or from the engine through the stat into the radiator?
Thanks, Greg
Old Apr 22, 2005 | 03:47 PM
1973F100's Avatar
1973F100
From the engine, through the thermostat, into the upper radiator hose, into the radiator.
Old Apr 22, 2005 | 05:23 PM
gwuister's Avatar
gwuister
Thank you. I installed a mechanical water temp gauge and fitted the sender in the fitting on top of the thermostat housing. The stock gauge moves as the engine heats up, but the new gauge doesn't move until the stat opens, then it works fine.
That answers that.
-Greg
