Extracting the distrubutor from the block.
Old Apr 22, 2005 | 01:03 PM
alxsnmr's Avatar
alxsnmr
I am having a difficult time convincing the distributor to come out of the block of a 351M. I need to reset the distributor's position due to the vacuum advance getting too close to the thermostat housing. I also need to reset it to get the engine to become advanced enough in the timing for it to run level.
Old Apr 22, 2005 | 01:50 PM
bigdaddy25's Avatar
bigdaddy25
I needed a large prybar to remove mine. Some things bind up after 25 years........course, I had no intention of reusing mine when I was done.
Old Apr 22, 2005 | 01:51 PM
312's Avatar
312
keep spraying around the base with penatration fluid.keep tapping it and it will let go in time.
Old Apr 22, 2005 | 02:39 PM
7fords's Avatar
7fords
312 is right soak it good then as you tap it turn it full rotation side to side as you lift up on it if you pry with anything dont over do it if real stuborn i have used the curved end of a prybar under it while tapping the other end of the bar with a rubber mallet carb cleaner then lots of wd40 is a good combo
Old Apr 22, 2005 | 04:15 PM
alxsnmr's Avatar
alxsnmr
Sounds like a winning Idea to me. Maybe I should polish up the area a bit when I put it back in as well. The timing is so close now that it has a nice rattle in the valve train when decelerating from a rev up.
Old Apr 23, 2005 | 04:20 AM
Torque1st's Avatar
Torque1st
Posting Legend
Smear some anti-seize on the base where it goes in the block. Aluminum and Iron don't mix well.
