Stalls when AC engages
Old Apr 22, 2005 | 12:01 PM
nibog's Avatar
nibog
Replaced the battery,1989 f150,302,Mazda 5spd,98400miles. When the AC cycles it stalls, normal idle seems slower also. After putting the battery in, I started it up and turned on everything I could think of, AC on high. I let it idle untill the temp needle started to move, and then drove it around the block twice, evrything seemed okay. Then shut the truck off, and restarted it with everything off. Drove it about 3miles and put it away for the night. Yesterday morning, I started out with the AC off, like I said, it seems to idle at a lower speed now. When I stopped at a light, I turned on the AC and it stalled about 10 seconds later. I was going to do the disconnect the battery for 05min, then restart and idle for 02min, then rev it up, trick tonight. After work so it will be thoroughly warmed up. The truck has the original TPS and IAC on it also.
Old Apr 22, 2005 | 08:30 PM
Popa Tim's Avatar
Popa Tim
I'd have the parts store check the alternators output. Running you should see about 13.6 volts at the battery
