72' 240 I6 rough idle
Old Apr 22, 2005 | 06:59 AM
ryans428's Avatar
ryans428
I just gor my truck about two weeks ago and I did a full tune up, and relaced the tranny mount and motor mounts, which were all original. But the engine idles a little rough, it doesn't die out though. Is this characteristic of this engine or do i need to rebuild the carb or something, Thanks
-Ryan
Old Apr 22, 2005 | 10:13 AM
Mikes67F250's Avatar
Mikes67F250
240
I have a 67 240 that I took out and replaced with a 300 with headers, intake and a 4brl holley. The 240 I have has 98,000 miles on it and it runs great with all the stock stuff. Even in the winter on the coldest days it fired up on the first try. It should run smooth. Check your timing, distributor wear and carb. Mine had a one barrel. Point gap may be incorrect as well. Hope this helps.
Old Apr 22, 2005 | 01:27 PM
idealtrucks's Avatar
idealtrucks
does it miss or anything when you rev it up, or does it just run like this at idle?
Old Apr 22, 2005 | 05:10 PM
mcapri1984's Avatar
mcapri1984
I have a 1970 F-250 with a 302. My truck had a rough idle too. I replace plugs, wires, cap, rotor, and still nothing. I was going to replace the points next, but just insted I replace the distritutor. That was the problem. Now it idles like a champ.
Old Apr 25, 2005 | 11:26 AM
ryans428's Avatar
ryans428
It's smooth as can be once it's revved up or is cruising,it only does this at an idle. I cleaned the points and the gap was already right, they looked kinda new. It smells alittle rich at idle also, but it sound like its missing at idle, when I crank it up cold you have to pat the gas while it's running you can't just hold it down 1/4 way or anything, you have to hit it and then let off or it will die. Thanks for the help y'all
-Ryan
Old Apr 25, 2005 | 12:09 PM
idealtrucks
have you checked the float level?
Old Apr 25, 2005 | 02:48 PM
ryans428's Avatar
ryans428
No, I forgot to do that, I'll check it when i get off work tonight.
-Ryan
Ryan78F150
New Member Introductions
Jun 10, 2014 03:23 PM
Hurk
Nov 28, 2008 07:21 PM
wolffee
Oct 27, 2008 05:34 PM
sr_ryan1
1983 - 2012 Ranger & B-Series
Apr 11, 2004 09:18 PM
